Water inlet
mbuco
New Member
4 Jun 2007
Slovakia
Hallo,
I am planning to install sea water in the galley, so I bought bronze water inlet. There is hole for screw in the water inlet.
My dilema is which type of the screw I can to use ?
Bronze, brass, copper or stainless-steel ?
Bronze would be best. Probably easiest to use a short length of bronze bar, threaded at each end (called a stud), with a bronze nut and washer on the inside of the hull..
