noswellplease
After the boatyard fitted a new prop to my boat I noticed water ingress. This was evident in the bilge when I boarded the boat which I simply pumped out. I put it down to the heavy rain we had been having and suspected some undetected weakness in the deck
This week after no rain I noticed the same thing however the water level had risen quite a bit in the bilge.
Recently after boarding at least 6 inches was evident in the bilge, (a 12 mile trip across the bay with friends planned) Pumped out dry , start trip, but water back to same level within 30 minutes. Trip cancelled, back to boatyard, lifted out and found one of the two bolts holding the through hull bearing for driveshaft missing.
Question mechanic who worked on boat and informed due to wear and tear, "its an old boat" he said.
My question. Can a mechanic actually change prop and there was a lot of pulling and pushing to get the prop in due to space restrictions etc. and not fail to check the integrits of this fitting and also what precaution might be taken to ensure it does not happen again. I don't think "wear and tear" is good enough it seems more like criminal endangerment to me?
Anyone have views on subject or experience something similar. If the electric bilge pump didn't work, well best not dwell on that!
