GunfleetSand
Will make some time to do some more investigation myself but wondering what the group thought.
Would water in gearbox of a Yam F30 four stroke cause enough rust to give slow crank/hard to turn over engine?
Battery is new (800CCA) starter is clean, spins and engages with flywheel. Bypassing solenoid - in fact direct from battery to starter makes no change.
Have always felt it’s something in engine too hard to turn over - stuck pistons. One mechanic says head gasket.
More recently another mechanic suggested gearbox might be rusting due to oil seal leak. Service in October confirms water present as showed some milky oil, didn’t look major so was replaced with new oil and out in the list of future repairs. Seems unlikely to me but could over a few weeks there be a rust build up causing slow or no crank?
Yes engine in in neutral. If I remove plugs and turn over engine it very slowly cranks then speeds up to a high crank, plugs back in fires up. After that will start on the button.
Plan to drop leg/gearbox and see if there is a change to free movement . Will also check engine oil (looked perfect/lovely colour a few weeks back) inspect bores with scope and do a pressure test
