unclebraddah
Active Member
Bukh DV20.
Lip Seals on the Water Pump were bad and the relief hole clogged. I got a lot of water in the engine mixing with the oil.
I put on new seals and the after sucking, not draining the oil out it is still sluggish and hard to turn over.
I took apart the raised hand start and there was goopy glug in there. So I know I need to drain from the bottom. Ive run a few quarts of new oil through (The filters off and iIhave a new one) it. Today Im doing the oil pump.
Im thinking of filling the engine with diesel and letting it sit and then draining it. Good idea? Bad? What should I do to get all the remaining water/oil/sludge out?
