rajjes
Hi,
I have discovered a slight leak where the deck filler hose joins the water tank filler. After attempting some bodges I decided to renew the hose as it has completely hardened with absolutely no flexibility. This is the original hose on a 1980's moody so overdue for renewal in any case.
My problem is that the tank nozzle is 48mm as measured with a caliper but I can only seem to find 50mm hoses locally in Malta. The supplier assures me that it should tighten sufficiently using 2 clips however I'm not convinced. I really need a tight seal since the nozzle is on the side of the tank so would be below water with a full tank.
Am I right to be concerned? Any suggestions appreciated!
Regards,
Duncan
Regards,
Duncan
