LittleSister
I'm trying to rationalise the exhaust system on our project boat (currently 14 joints between engine and final outlet!). The engine's a Bukh DV10.
There is a second water inlet (i.e. in addition to the exhaust elbow) into the exhaust via a small bore pipe and T piece in the exhaust, after the water lock. The small bore pipe is shown on Bukh installation drawings as coming from the highest point of the water cooling circuit, before the exhaust elbow, and joining, above the water line, the fall in the exhaust to the hull outlet. The small bore pipe is referred to as a 'bleeder pipe' on the drawing (though note the English translations of Bukh part names can be quirky).
As far as I can see this is an anti-syphon pipe (when the engine stops the water in the cooling system can fall, drawing in air via this pipe to break the syphon path). Could there be any other explanation/role for this?
If I am correct, this second inlet into the exhaust is redundant as we also have a syphon break 'piddle tube' into the c ockpit (also coming from the highest point of the cooling circuit), and I can dispense with it.
