Watchet Marina Tidal gate Update...
tonybarebones
20 Sep 2006
Dinas Powis, Vale of Glamorgan.
FORENSIC tests and detailed examinations are being carried out on the damaged tidal gate at Watchet Marina after it was successfully ‘floated’ out of position on Wednesday.
A five-strong team of marina staff and local company Exmoor Welding worked for ten hours to remove the gate, using airbags provided by a specialist company.
“It was a precision job and it was a tough day but it’s out and we are delighted that it went so well,” said a marina spokesman.
The operation began on Tuesday and the team worked mostly in the rain to complete the work.
The seven-ton structure was finally craned out of the water and onto the East Quay at about 5pm on Wednesday and was due to leave Watchet yesterday (Thursday) bound for Hunton Engineering in Kent.
“This is the only cill marina gate to have broken in the last 50 years according to the gate designers,” said the marina spokesman.
“It is believed the failure was caused by an object becoming stuck underneath it.”
The gate has been out of action since the beginning of September but marina staff have worked tirelessly to keep the facility open to boats.
The tests and assessments will determine whether the gate can be repaired or will have to be replaced.
All content © of West Somerset Free Press unless stated otherwise.
Does anyone know what the situation is now the gate is removed ?
ie - is there a tempory gate or is an open tidal flow - and drying marina ?
May be wanting to pop in over the winter months if I leave her in - and its likely to be
after hours late evening ?
Geoff
i should think they will be using the stop baulks, and removing/adding 1 or 2 dependant on tide height?
i think you can still get in/out with notice.
