thethrillisgone
New Member
Hello,
New boat owner here but with years of RV experience. Waste holding tank is a Tektank 277 liter and was installed by previous owner. It never seems to empty all the way, the vent is clear and connected with proper reinforced hose. Had a look at it today and the pump out hose is fitted to the top of the tank as are the others. Inlet, vent.
There is no extension pipe on the pump out fitting that extends into the tank. It is essentially top surface mounted.
Seems to me the pump out hose should be near, or at the bottom of the tank, and that is my question folks.
Should the pump out hose be located at the bottom of the tank?
Thank you in advance for help on this!
Phil
Phil
