Wardrobe Water and Teak corking
c_j
6 Aug 2001
Poole Dorset and Palma Majorca
Two questions for the panel.
Last weekend the Wardrobe in the starbouard aft cabin on my Targa 48 had around 3 inches of fresh water in it. I removed carpet from floor of Wardrobe and the floor is in fact a plastic dish about four inches deep ideal for holding water.
We cleaned it out (fresh water) and tried to replicate leak by putting loads of water over screens, window etc, but it stays dry as a bone. any ideas?
Question two:
We cleaned off teak using a two part cleaner and then applied Semco sealant.
We notice now that the surrounding black corking is softening and easily smudges on to teak. This is not the corking between the teak but the corking that is used to fill the joint between the edge of the surrounding gelcoat and the teak decking.
Our neighbours are starting to get a similar problem.
Any one else?
Any one got a cure?
<hr width=100% size=1>CJ
chris@stone.uk.com
<A target="_blank" HREF=http://www.stone.uk.com>http://www.stone.uk.com</A>
tcm
11 Jan 2002
Caribbean at the moment
Mine had the same probelm on the port hand side. I believe that water entry point *might* be aroudn the back of the nav lights. Or thru the window, then it runs forward, down the back of the wardrobe.
It wd be a good idea to dismanltle the thing a bit to gettit dried out mebbe, easy enuff, all crosshead screws and pieces of veneered ply.
