I've got a Wallas 1800 B (it says in the presumably Finnish manual) on my new boat. I've never seen a paraffin heater before so a voyage of discovery was had today. When I turned it on the fan worked, but no other noise so after a pair of legs sticking out of a cockpit locker for a while I had a cover off and took out a pump which seem far too silent, took it apart and sanded down the contacts. Success, after getting some fuel to it the pumping rate slowed down to about one every half second. So with the fan on full blast I pushed in the starter button for a while, some smoke came out of the vent and the unit seemed to heat up a little but nothing else. I've scoured the internet to try and find out what goes on inside but no success. So how do these things work and am I following the correct starting procedure. I don't speak Finnish but I reckon it says:
turn on "Burner"
Turn fan to 'full'
push in start button for 60 seconds
red 'heat' lamp comes on 3-4 minutes after starting
some heat after 5 mins, full after 30 mins
if red lamp doesn't come on after 5 mins push start again for 60 secs.
Also, will I be able to hear if the unit is lit ?
Thanks in advance
Paddy B
turn on "Burner"
Turn fan to 'full'
Thanks in advance
Paddy B
