walker trailing Log
johnalison
14 Feb 2007
Essex
A walker log can be subject to the odd error, as when going too slowly of when it picks up a little weed but generally it should be pretty good. I used to use one regularly to calibrate the pathetic old Navico log on our old Sadler. I regarded it as much more reliable than a measured mile in a tideway.
20 Feb 2014
Thanks for the link, I use a walker on longer trips, bit of nostalgia I expect, but the link suggested that the line should be calibrated length wise to the unit. May be I am missing something, but why does the length effect the reading, the spinner revolves at the same revs at a set speed regardless of cord length, and the revs determine the reading.
sarabande
6 May 2005
the longer the line, the more resistance to rotating, and there may be a function of the angle of the line to the surface of the sea.
