MagicalArmchair
As well as the grim job of smashing my mast truss out, I'm doing some more fun jobs like refitting the galley with a fridge and a Corian work surface.
My fridge box is made with Robbins marine ply, a layer of glass matting, and three coats of white pigmented epoxy. I have my Celorex ready to insulate it, and before I cut the lid in the top and epoxy on the final side on, I want to fit the cooling plate. Does it matter which way up this goes? The instructions (edit: http://www.waeco.co.uk/docs/Cooling around the world new.pdf) are unclear:
It fits better this way up with a gap either end so cool air will still fall down:
This way up it doesn't quite fit, the box would need a little modification:
Also, I was going to epoxy the pipe in to make a seal. Good idea? Or just make a hole to pass the pipe through and seal with silicon sealant so it's easier to remove? (edit: They suggest foam! Doesn't sound very enduring or tidy to me...)
Any other tip before I seal and install the fridge box?
