Waeco coolmatic
kid's inheritance
1 Sep 2010
San Carles and Windermere
Before cack handledly messing up the Waeco , there are only two controls. Maximum and minimum I can just about work out, but the battery monitor has low, off and high. The Waeco website doesn't explain their functions , can anyone oblige?
TIA
Rob
Check the website/manual for battery state monitor.
Going from memory now ..........
If you are running off your starter battery then you dont want to run your battery down with the freezer, the freezer cuts off at a certain voltage determined by the low high.
if running off dedicated deep cycle domestics run it on 'off' or 'low'.
if you are running off starter run it on 'high'.
