Trevor_swfyc
Help this is driving me insania! I have fitted a new Hawk Antenna and wind indicator. The old one worked but as I was up the mast fitting the Nasa wind speed cups I would treat the boat to a new aerial. The fitting looked idiot proof, but no try as I might the reception is somewhat lacking like dead. Thought it might be the radio fitted a spare old aerial and it worked so radio is ok. Rewired the plug to radio still dead, went out to the boat today to try another plug cut the wire off the plug and got a static belt off the wire. The cut wire was actually hissing as static jumped from the outer to inner core.
It looked to me that the hollow nosed bullet that fits to the aerial is pre wired is this correct or do you have to pull the bullet off the wire and wire it up?.
Note also I wired through the deck with a gland so the wire is continuous from the aerial to the radio.
I have sent an email to info@communicationaerials.com but in the meantime any help would be much appreciated.
Trevor
Trevor
