Bagarn86
New Member
Hi,
I have a VP2030D with reverse gear and straight axle. Had the reverse gear removed to change the rear crankshaft seal earlier this year and after that refitted the flywheel housing etc with a new plastic gasket between the housing and engine block to isolate them. However now during the season I noticed the anode on the propeller shaft and propeller seems to wear very quickly so decided to measure between the engine block and flywheel housing with a multimeter/summer and it seems they are connected anyway! I get a clear tone on the summer when the multimeter when measuring with the probes on the reverse gear and engine block.
When I fitted the plastic gasket and ring (no 28 and 29 in the pic) I applied a small amount of grease on the flywheel housing surface to keep the plastic seal in place when fitting the housing back, could it be that somehow connects the engine block and reverse gear? Dont really know if this is the proper way to measure it though, anyone have any insight and/or tips?
