PatrickSeb
New Member
Long story short, problems isolating MS25S saildrive from VP D2-55 engine after renewing flexible coupling at flywheel. Measuring with a multimeter for continuity, and eliminating bolt by bolt etc, I end up splitting engine/gearbox again. With a 2 inch gap and nothing attached to or against the gearbox/drive, I still measure continuity between engine/gearbox (!) Disconnected grounding cables from engine, and still continuity. Continuity through water is my first assumption. But where to begin? All through hull fittings are composite.
Constructive advice and ideas are very, very welcomed
