Cardinal
Has anyone recently fixed problems with these items and if so, how? Did you use a Bowman oil cooler and if so, how is it mounted etc. and did you also swap the heat exchanger for some Bowman heat exchanger?
Thanks BD. I guess I need to get on and pull it apart to be sure but I have been working on the assumption that the oil cooler will have corroded causing it to deposit most of the engine oil into the bilge. There is no other cause apparent so far.
Thanks. Are you referring to the HE or the oil cooler?
