VP 2003 engine alarm, and warning lights, not working.
Stemar
12 Sep 2001
It was. Moving it outside was so much better than having to leave the tiller and go head down in the companionway with 250,000 tons bearing down on you!
Just use waterproof switches and protect the back of everything. You can use LED warning lights for oil and temp, but the charge warning light powers the alternator field coils, and they want the tiny current flow through a filament bulb to kickstart them
VicS
13 Jul 2002
This can be overcome with a secondary feed via a resistor to the warning light connection on the alternator.
More recent VP engines have a feed from the ignition switch via a 33 ohm ( 5 watt ???) "excitation" resistor
Some alternators ( eg Hitachi) have a second terminal which is fed directly from the ignition switch ( there's an internal 50 ohm resistor)
(You may find this on your Beta20 engines)
