Volvopaul !!!!!!!!!!!!!!!!!!!!!
Steve,
If when you launch and test this epc repair you still have overheat problems, I presume this is why you started on this road. Particulalry if this occurs above displacement speed, consider replacing the water inlet hose rom the transom to the sea water pump with a reinforced clear hose. 1.25" ID required. This will allow you to see if any air is being drawn into the system as the boat rises onto the plane. If so the problem may lie with theoutdrive and water hose connection.
Good luck.
Springer
