gyislander
Hi I wonder if anyone can help. I'm having problems with the trim tilt on my Volvo 290 sm. The accuracy of the gauge has always been a bit iffy and although I know I should have fitted a new sender I didn't as it all still worked in the yard (although i never had it fully down due to clearances) Now it's back in the water and after I trimmed it fully down, the gauge is reading fully up and the motor will no longer activate to raise it.
I'm wondering if that's because it thinks its already fully up,,,, is the system that clever ? I'm going to disconnect the sender wiring to see if it will respond and welcome any other suggestions to avoid having to lift the boat back out again for a new sender.
Has anyone experienced this ?
