alt
Hi all,
KAD300 on DP-G Drive.
Returning to home berth earlier, the stbd trim pump would not do anything (up or down)
The relays are clicking when you hit up/down. When you press the red button on the trim for beach mode the relay at the dash clicks.
When I connected to the port side (using a 2 core cable), the pump fires up, so the pump is good.
The LCD display for the trim angle works.
No diagnostic issues, engine runs fine.
I checked the following fuses, all OK:
2 fuses under the black box (Blade 7.5A)
Push fueses (2) in the black box
Single fuse next to the starter motor (Blade 5A)
This is clearly a power issue. I traced the black / red wires from the relays back to the engine. They go behind the engine and across to under the intercooler and after that i'm not sure where they go.
Wondering did I miss a fuse somewhere?
Everything else works!
