SailingVet
Active Member
Hi
I have a volvo D4 engine set up with Teleflex wheel steering via rams on the legs.
It leaks at the wheel - left full lock comes to a stop and fluid leaks out somewhere under the cover - seal on the wheel shaft? Or if you push hard on left lock the filler cap blows out and everything turns pink!
Right lock doesn't come to a stop in the same way - resistance increases but you can still keep turning the wheel.
Legs move OK from lock to lock.
The local engineer here in the Med. doesn't seem to have an answer and as we've just gone from sail with cable steering to this I can't get my head round the connection of the parts - PS pump on engine, wheel "pump/valve", rams and is there something else linking these parts. Plus can't get my head round the ATF flow round the system. Not sure if it's high pressure ATF going through the wheel or if that's separate and controlled by the wheel via another so far undiscovered component.
As you can see, confusion reigns.
Any help or explanation of how this all works would be much appreciated.
Andy
Andy
