Marcos puerto
Acceleration issues
That’s limp mode. Deliberate to protect the engines. Press the diagnosis button and count the flashes.But still the engines are limited to 1.000 rpm.
Any idea of whats happening?
Regards marcos
Hi there, pumps where not touched, control panels don’t show any failure, batteries are very deficient, tomorrow I am buying new ones. Fuel lines perfect, actually I bought a new harness to se what happens and nothing changed. In my opinion the engines are electronically limited to 1.000 rpm. The system is detecting a failureCould be anything, most likely related to the latest interventions.There’s been a lot .
The “;EDC “ - is everything plugged in put back correctly, the fuel lines clear , the diesel pump rebuilt , any rev sensors connected + calibrated?
Timing of diesel pump and gen valve gear . There will be a critical sensor somewhere get a guy with a vodia system to plug in and see if it’s any use .Any codes on the dash thrown ?
Its not the cooling , system or paint unless its gotten into connector .
He also told you to look for any codes on the dash. And I told you how.Hi there, pumps where not touched, control panels don’t show any failure, batteries are very deficient, tomorrow I am buying new ones. Fuel lines perfect, actually I bought a new harness to se what happens and nothing changed. In my opinion the engines are electronically limited to 1.000 rpm. The system is detecting a failure
You don’t need a scanner. Press the diagnosis buttonThe only failure at the moment y the battery alarm , in the control panel no failures at all, well for the moment I dont have any scanner around, if I find one than I will coment the failures and see how it goes with new batteries
Thank you very much for your interest
