Volvo single gear/throttle lever for MD2002 18hp engine
Sybarite
7 Dec 2002
France
Would anybody have a diagramme setting out the lining-up of the gear wheels etc.?
I dismantled mine for cleaning and now find that it is not as easy as I thought to put the jig-saw back together again....and I don't want to make a mistake.
Many thanks.
John
PS it's not in the engine manual.
One problem you will have is that most go together a couple of different ways depending on the configuration of your engine throttle/gearshift.
It depends on whether you have a pull or push throttle.
It depends on how far your gear shift lever needs to move to engage gear.
It depends on whether you pull the cable for forward gear and push for reveres or vice versa.
Sorry that's not much help, but the wear marks should give you an idea of which bit went where last time.
