samwise
Is there a sovereign remedy for getting that nasty blue Volvo grease into the rubber engine shaft seal? Ours is about a year old and I find it hard to prise the rubber off the shift far enough to introduce the grease. Clearly I don't want to distort the seal, but it seems impossible to do it directly from the tube, even if the top is flattened a bit. I have heard of, but have not yet tried one possible solution using a small polythene freezer bag with the corner cut off. Any advance on that one? Also, should the seal be lubed after every haul out or more frequently?
