28 Apr 2014 #1 T trophy160 Active Member Joined 22 Jun 2008 Messages 42 Visit site Can anyone confirm the gear ratio for the 120SE, could I directly replace with a 120SB which is 2.21 : 1
28 Apr 2014 #2 VicS Well-Known Member Joined 13 Jul 2002 Messages 48,740 Visit site trophy160 said: Can anyone confirm the gear ratio for the 120SE, could I directly replace with a 120SB which is 2.21 : 1 Click to expand... 2.2:1 is the ratio of the lower unit. I am finding the same ratio for the 120SE but I cannot guarantee there is no variation. Your engine owners manual will tell you the ratio in the Technical data section.
28 Apr 2014 #3 T trophy160 Active Member Joined 22 Jun 2008 Messages 42 Visit site OK, thanks, it is the leg I need to swap out so that sounds like it should be fine. I had a quick flick through the boats manual tonight but did not see the drive ratio, perhaps I need to go back and read it more thoroughly
28 Apr 2014 #4 S Slowtack Well-Known Member Joined 27 Feb 2007 Messages 2,825 Visit site Check here.................... http://www.marinepartsexpress.com/outdrives.shtml
