VOLVO QL TRIM TABS
spannerman
30 Nov 2002
Do you mean the blade type?. In which case yes, I tried them on a naval patrol boat, they generate drag as much as lift and were used to steer this particular vessel which did 42 knots on jet drives. They will not provide much lift at low speeds which is when you most need it on a planing boat to get onto the plane and I am convinced that the conventional flap type give better results for most applications.
Steve /forums/images/graemlins/confused.gif
Will_M
26 Jul 2001
GBR
There were a load of test reports on these in the mags around Southampton/Sept show time last year, the mags gave them a huge thumbs up if I recall.
The QL boat trim system as its called it isn't available till around March/April time though.
