Volvo Prop Fitting
Margem
1 Jun 2001
Leicetershire
A well known Volvo sevice dealer has just fiited a new pair of props to one of my 290 outdrives. The large prop nearest the drive has been left loose due to the nylex type locknut not being fully cranked up, is this correct, i realise the prop cant come off, but there is a small amount of play in it. What do you guys think?
I just went and checked mine. No movement at all. Perhaps you should get 2nd opinion. A loose prop would not be a good idea.
Is this Volspec @ Haven?
Hell that's worrying... Pm me if you dont want to make it public, will keep that in mind when i have mine done proper like!
Cheers,
Craig.
They should most definitely be tight. I should check your anodes are bolted up tight as well, the same lot left one of my ring anodes loose last year.
