picardy
I have a 2006 year Volvo D1A with a 130B sail-drive with around 200 hours use.
The sail-drive seal was replaced last year and the sail-drive has been refilled with red oil (presumably ATF)
I understand I should now be using VDS3 engine oil. If so can I simply drain the ATF and refill with VDS or do I need to flush it first?
Also is it simply a case of removing the bottom drain screw and then filling once the screw has been refitted?
Do I need to be doing anything else?
Thanks in advance
Thanks in advance
