jbm1967
Hi, my saildrive has developed a sudden fault. It has very little power (just a little at low revs). It is making a not good noise. Sounds like the prop is hitting something. The prop will rotate by hand when in gear but does rotate slowly when engine is running in both forward and reverse but hardly any power and does not increase much with revs. Could this be the rubber coupling inside the prop? Or something more serious? How best to check? Are these saildrives easily rebuilt or best to look for a second hand one if its actually the saildrive? Oil looks clean and is changed regularly. Thanks for any advice.
