jmuir1
Active Member
Hi
Problems ongoing with tachometer not working. I ve checked all connections and also removed alternater to get it checked in a professional workshop. They couldn't find anything up with it? Last year it was variable and needle on tach. would drop and alarm would sound but engine didn't skip a beat. Still on the hard and have put alternater back on a now and on starting the engine it very occassionly works then drops to zero. I've wiggled the key and think there is an issue there as all warning lights on panel do not always light up on first turn point of key. I think from memory they should all light up and then go off once engine is running...correct me if I am wrong. Is there anything I should check further. The charging light would occassionly stay illuminated on starting but goes off if I gently move key slightly, again making me think there is an issue with the key connection, would this affect tachometer too?
Any views ideas appreciated,
John
John
