Volvo Penta MD22L Perkins Prima Glowplug Relay Fixed
Polly1
2 Nov 2009
Singapore
My Volvo Penta MD22L also Perkins M50 has three relays by the engine. The start key has 5 positions starting from anticlockwise, being Engine stop, Off, Instruments, Glowplugs, Starter motor engage.
To stop the engine the stop solenoid is earthed via one of the relays and positive is supplied at the same time. Hence a past attempt to stop the engine via adding live to the solenoid had no effect (it is not normally earthed). The engine will run with the key in the off position. In order for the alternator to energise and generate current the instrument light connection needs to be made.
Since owning the boat I have had a variety of electrical faults often due to bad connections. I replaced the loom connector at the engine end with direct connections (I soldered the wires together). The lack of an engine earth puzzled me for a while.
I have had the engine fail to start at sea a few times but live onto the starter solenoid has always worked and it was always down to corroded or sulphated contacts. This time I swapped two of the above relays looking for poor connections and found I could start the engine but not stop it and vice versa. One of the relays had burnt out (originally the glowplug relay), the other two energise the solenoid contact and the glowplugs. I replaced the 50A relays (4 pounds each) and saw the glowplug light on the instrument panel for the first time (it had been burnt out since I owned the boat). However the light wouldn’t go off when the engine started and the relay was getting hot again. This lead me to look for a timer or a system whereby the alternator voltage would cause the relay to switch off, but the solution was the start switch had a worn position that I had overlooked, position 3 in my list. Now I need to take care to avoid running the engine with the switch in position 4
I don’t think this is the last I will hear from my electrical system!
I also have read on a variety of forums that this engine is free wheeling or words to the effect that if the cam belt breaks the valves will not hit the pistons. After replacing the head I found this not to be the case, if you rotate the camshaft separately from the crank the valves will contact the pistons.
I hope that this will be useful to someone, the engine seems to be quite common on older boats.
We had the same problem with our start switch. After starting the engine and releasing the key it would sometimes stick in the Glow Plug position. Next the actual Engine Start position failed. A new Start switch is over £200. Right now we use the start switch to turn on the ignition and a push button to actually start.
skipper_stu a member here is very knowledgeable in respect to MD22's hopefully he will comment on this.
In a vehicle with the Prima the glow plugs have a timer, which IIRR, keeps them on for 11 seconds after starting. But there is only a an On and Start position.
And yes, a bust cam belt WILL wreck the cylinder head. Seen it happen.
The Volvo key switch is known for that problem. It could be resolved (if the switch is otherwise ok) by removing the glow plug connection from the switch and routing it through a glow plug timed relay, taking the live feed from the key switch and running a permanent negative to the relay. You'd need to modify the wiring to the glow plug light or fit a separate warning lamp, or have no light. When you turn the key to the "ignition" position the relay would close and energise the glow plugs, when the light goes out you start the engine.
In a similar fashion, the stop position can also be disconnected and a stop button added, the button would work via a relay to energise the stop solenoid. Care should be taken with Volvo stop solenoids, if they remain energised they will quickly burn out. I just replaced the stop solenoid on a TAMD70E, cost of the solenoid from Volvo........£400 !!!
Similar stuff happened on mine, I wrote it up for PBO, they printed it last month or the month before.
