Volvo Penta Instrument Panel (KAD/KAMD44)
wizzer
27 May 2004
Ever sunny Cornwall
So, I’m thinking there’s something awry with my VP instrument panel warning lights.
Port engine:
Turn on ignition
3 of 4 warning lights illuminate
No low oil pressure alarm
After 20 seconds, first warning light (engine temperature), goes off, leaving oil pressure & battery voltage lamps lit.
If alarm test button pressed, alarm buzzer sounds & engine temperature lamps lit lights again (along with the other two)
Starboard engine:
Turn on ignition
No warning lights illuminate
After 10 seconds, the low oil pressure alarm sounds & the oil pressure lamp illuminates
Note that the above conditions are the same at both the lower & upper steering positions
