Volvo Penta Hour Meter Replacement
Paul w
21 Oct 2011
Cumbria
I am wanting to replace the LCD hour meter built into the Volvo Penta rev counter. The replacement hour meter module is available from Curtis Instruments (which is a 701PN00101248D Part No. 17075110) at a cost of £14 plus P&P.
The problem is, Curtis have a minimum order of £50 +vat so I would have to order 5 hour meter modules.
Would anyone be interested in obtaining one of the 4 spare hour meters at cost?
Paul
Plevier
22 Aug 2008
Brighton
Do your own check but I think this http://uk.rs-online.com/web/p/hours-run-meters/1856107/?origin=PSF_381789|cav is the same and available singly from RS. Would like to hear your conclusion as I was thinking of getting one.
However if there is any doubt and you want to go for the Curtis unit count me in for at least one. I will check with a friend who I think also needs one.
Can you PM me when you have news please?
Paul w
21 Oct 2011
Cumbria
HI Troubadour,
Have looked at the RS hour meter, I cannot confirm that this will replace the hour meter in the Volvo Penta rev counter.
However, having read a few articles and also spoken to Curtis Instruments, there unit will definitely fit.
Paul
ianat182
10 Jul 2008
,home Portchester
I seem to remember a thread on here re the non-working VP hour meters, due apparently to dampness in the unit.The 'cure' was to take home and leave in the warmth of the airing cupboard;the hours are retained in the memory when re -fitted.
One of our forum friends had a few for sale,so may be along if he still has them; also there was a separate thread describing exactly how to remove and replace the old with a new unit ,within the last few months. mine has packed up too, so having to log hours run till I get around to it.
ianat182
ianat182
Harry25
14 Sep 2006
West of Scotland - Kintyre
Try this
Copied this from Sealine Forum http://www.dolcetto.org.uk/downloads/Replace Volvo Penta Hours LCD.pdf
The original part on the instruction appears to be obsolete but this is the part that RS stock RS part no 185-6107 and manufactured by curtis instruments
http://uk.rs-online.com/web/p/counters/1856090/
Backlight No
Connection Type PCB
Digit Height 5mm
Display Type LCD
Inputs Solid State, DC Voltage
Main Count Mode UP
Maximum Input Frequency 500Hz
Number Of Digits 6
Panel Cut Out 26 x 7.6mm
Presets 0
Product Index Totaliser
Resettable Yes
Size 15.4 x 31 x 1937mm
Supply Voltage 12 → 48V dc
PDF download version on above hour meter module spec http://docs-europe.electrocomponents.com/webdocs/001a/0900766b8001abd9.pdf
