solitaire11
hi all, whilst on my 2 week break im cruising along nicely at 20 knots(3000 rpm aqd41a 10 year old) when the revs die on the starboard engine and theres a knocking noise coming from the back, so i immediately pull back to neutral when said engine stops(b*%$!?^¬s) says me, then try to restart it justs clicks (locked solid) next day i thought id try it and it started although knocking so switched off again. so when i get home i put big socket on crank pulley and it wont budge. thinking about taking head off to have a looksie when friend suggests it might be drive that is locked up(290 dp), the more i think about it the more logical it seems as there was no smoke oil pressure and temp was fine only done 190 hours since volvo rebuild, and if it was engine ie valve conrod crank causing it to lock up with the socket you should be able to reverse it? anybody ever heard of this before??? any info greatly recieved as its startin to get to me now. thanks in advance.
