Cactus Sailing
Had some issues this weekend with the inboard, it has four buttons on the start panel
Start button
Stop button
Alarm reset
On/off button
Admittedly I left the isolator in over night but I was plugged into the charger but when I came to restart the buttons did nothing, the control box wouldn’t even switch on
Battery voltage was good etc
So I left everything off while I was checking voltage of batteries and switched isolators back on and the control panel beeped back on at the helm
Started engine but it cut out spluttered with stop signal on display
Would not switch back on so I isolated everything waited 5 mins and it started as normal
20mins of motoring later I popped to the fuel berth and needed to switch it off (I had 1/2 tank but wanted to top up) well it just didn’t want to turn off ?!?!?
Used the manual cut off on the engine - filled up started as normal but now the stop button appears to not Be working - any ideas ?
The panel is sealed in at the helm so before I picked the sealant away to test the switches thought id ask for clues? Was working wonderfully only yesterday!
Start button
Stop button
Alarm reset
On/off button
