sfleron
Hi All
We just purchased a Bavaria 37 HT form 2009 with a pair of D6-330. We went on seatrial last Thursday and everything was just running smoothly. Went to pick it up and sail it home the day after, and here she would not start PT engine.
We managed to wiggle cables and stuff and got no errors and started to get home. 5 days later we arrived at our harbor and had engine issue on PT every day. Had a VP mechanic on board with Vodia tool to check and it was clear that the data link cable between HCU and PCU was bad – he had a test cable with him and connecting that things worked. We took the one out that apparently was faulty and tested it… there were no errors at all, connected it back, auto calibrated and no problems.
3 hours later we wanted to start as wind had slowed down and same error again, wiggling cables, auto calibrating and managed to get on the move….
So now back safe in harbor I went to test what is going on… here is what I found:
Swopped cabled from SB to PT PCU and also at the HCU to see if I could move the failure to the SB engine – no luck at all, still the same.
Took the main power fromswitch engines, waited 3 mins and repowered… error still there:
FMI 164
SID 253
FMI 9
And
MID 164
PSID 218
FMI 9
These indicate error in comm betheen HCU and PCU.
Did auto calibration and got:
MID 164
SID 253
FMI9
And
MID 164
PSID 99
FMI 12
Last one indicates that configuration is lost
I then reseated the large connector on the PCU – that gave me a new set of errors:
MID 164
PSID 99
FMI 14
And
MID 164
PSID 99
FMI 12
These indicate that comm is good but config is lost… so I auto calibrated again and all errors were gone – I could start engine and had full control.
I shut everything down and took the main switch again, waited 3 minutes and repowered – then the issue was back.
I could suspect the PCU, but reseating the large connector (X3)on the PCU seems to do something, so wondering if there could be something else that makes the PCU fail on startup…
When I got the first set of errors I notice that the tilt sensor showed 56, no light in neutral, engine would not start with error “Engine in gear unable to start”.
Strangely we found (during 4 days of sailing) that one the error is gone everything works perfectly throughout the trip – but when we power off the error comes back. Again reseating seems to do something good…
I also notice that the actuator is no moved when applying ignition when the error is there.
Would you have any ideas of what to look for?
Thank you all
BR Soren - Denmark
FMI 164
SID 253
FMI 9
And
MID 164
PSID 218
FMI 9
MID 164
SID 253
FMI9
And
MID 164
PSID 99
FMI 12
MID 164
PSID 99
FMI 14
And
MID 164
PSID 99
FMI 12
Thank you all
BR Soren - Denmark
