CJ13
We have a VP D2-40 (2006) and have recently had an intermitent fault with the Instrument Panel- it's the Instrument Panel with electrical stop/start function, & no ignition switch.
Occasionally after the engine has run for a while the Tachometer stops working - it reads 4500rpm and the Engine Hours Meter goes blank. At other times the Tacho is ok, but the Engine Hours Meter flashes off for an instant every 10-15 seconds or so, although it still seems to keep an accurate measure of the hours.
On 2 or 3 occasions at the end of the day while parking the alarm comes on for a few seconds- this is as were manovering around the marina and nothing to do with a sudden change in revs.
Does anyone have an idea of the cause and solution??
Many thanks,
John
Many thanks,
John
