Metabarca
Hi all, I've rather an urgent problem to resolve; hope you can help!
In the last couple of days, the engine has been on and off and has always started perfectly. Yesterday afternoon, we changed the oil, filter and water impeller, then tested the engine; all functioning perfectly. This morning, again started the engine, but immediately stopped it, as we'd forgotten to check the oil level. Oil level checked; very slightly over the max. Engine left alone.
Autoclave run for 20 minutes (change of water) with engine off. Then tried engine; clack! of starter motor pinion but engine does not turn over.
OK, we thought, batteries, are old and knackered; that's why we bought two new ones. Put new batteries in. Not known if fully charged but assumed to be so.
Same result: a clack! hard enough to send a vibration through the boat, but no engine turn.
Am now charging the batteries in case even these ones are only half charged (but indicating 12V). Have tried the fuse on the box behind the alternator: ok.
Any ideas as to what it might be? Thanks for all consideration!
