volvo penta 290 legs
DIOGENES
Active Member
21 Jan 2002
Rhoose, S Wales.
I'm lifting my boat out shortly for the winter overhaul and plan to service the legs. Not having done this before and with the boat out of the water for only a week i was planning to buy my parts now. The question is what parts am i likly to need, I already have the drive shaft bellows and anodes, what other parts am i likly to need???????????????
I'd replace the rubber washers around the drain/fill bolts too. If you find somewhere for these please let me know as I forgot to get some myself
Recommend that you also get 2 sets of the nylon bushes for the hook up forks.... pound to a pinch of pigsh*t they will be shot.. they are £6.44 +vat/pair from Keypart part no876507.
Might also need a replacement jubilee clip for the water hose
This may help
Item Volvo code
Zinc ring kit anode 875821
Zinc bar anode 852835
Zinc tirangle anode 872793
drive bellows kit 876294
Exhaust bellow kit 876631
Hose clamps 853548
Cotter 17253
Cotter pin 967707
Bushing kit 876507
O rings 955974
O rings 955989
Synthetic gear oil 3809443
Above are service parts for 290 leg, talk to Keypart & where they can they will supply their own brand
Regards
Timbad
Possibly exhaust gaitors,definately some leg oil and how about some antifoul both primer and topcoat.
What sort of anti foul and primer would be best to use?????
