Volvo Penta 2003T Water Pump stripping
Workshop manual Here but no specific mention of the turbocharged engine.
Diagrams and parts lists for two different pumps Here or Here
It would be short-sighted not to renew the impeller at the same time, also to inspect the wearplate, the end cover and the bearings.
hi just done mine on 2003 not turbo. Took less than I hour. Needed to punch out insides of pump, hammer with wood dowel, made up replacement kit as per the old one I removed and punched back in. The pump water in and out feeds are just push in fittings. Few bolts holding the pump to the engine. It was that easy. Raw water pump service kit with all the bits you need 60 ish pounds from keyparts or just the seals at 10 ish pounds. Impeller extra.
David
