NealB
Our boat has got the standard VP engine panel.
The oil warning, water temperature, and non charging lights all come on correctly when the power switch is pushed on, go out correctly when the engine runs, and come on again when the engine is stopped.
So all ok there, and, in particular, suggests that the oil pressure sender unit is working ok.
However, the low oil pressure alarm doesn't sound, either when the panel is switched on, or when I stop the engine.
So ..... oil light ok, oil alarm useless.
The alarm sounds loudly when the test button is pressed.
I've cleaned, tightened and Contralubed as many connections as I can find.
Can any of you clever electrical types suggest other obvious things to try please?
Thanks.
Ps just in case it's relevant, the rev counter doesn't work either but that's lower down the to do list.
Thanks.
