eladn
New Member
Hi there,
As the title suggest - I have a water leak from the fresh water cooling circuit on an old VP 2003. The leak is on the coolant T pipe (copper?) connecting the expansion tank and the pump/heat exchanger.
If you look at the attached drawing - it is at the point where o-ring 21 is located (for some reason the line connecting this point to the heat exchanger is missing in the drawing).
I have purchased the replacement o-ring, only to see that if I follow the workshop manual, it seems like the whole cooling system would essentially have to come off for this to be exchanged?
The pipes have a bit of a wiggle, but would it be enough to force it out without having to take off most of the other parts?
If I otherwise understand correctly, both the pump and the pipes leading to the pump at the front of the engine would have to come off then?
Many thanks!
Many thanks!
