Quirk
New Member
I have a dehler 28 with a Volvo Penta 2001 engine. The engine cuts out after about 20 seconds if I set to the throttle to the maximum setting. This does not usually happen if the water is dead calm, however, once it has happend on any particular day, the symptoms can be simulated while moored up on a pontoon with the engine in gear at maximum revs. Does anybody have any idea what could be causing the engine to cut out.
We have tried all of the obvious things; the fuel line and filters have been replaced and the lift pump has been replaced.
