BNR
Is it correct that the sail drive leg should be electrically isolated? My unit has a negative solonoid with a negative lead running to the alternator which in turn is bolted to the cylinder block. Therefore, the cylinder block is a negative return. Is this correct? If so, the negative side is connected to the drive leg!
