D3B
I posted before about the indicator telling me that the leg was up at 50 degrees. It wasnt. I am told it is to do with the sensor.
Engineer now on board and tells me one of the two cables from the sensor is broken. Needs to have leg removed to replace cable and sensor. He says it could have been faulty parts but could also have been caused by hitting something under the water or someone poking about.
I have heard a lot about duff sensors.
Engines/legs only two years old but 250 hours.
Does the panel think this should be covered by warranty.
Estimated time 3-4 hours @ £35 per hour + vat, plus sensor (approx £80)
Also been said that its only the indicator and you should be able to set the legs by how the boat feels and is balanced. must admit when out over the weekend i did tweak the legs to get a nicer balance than just using the numbers shown.
Doug
Doug
