Jaz
New Member
My 5 tonne Seacracker fitted with Volvo 2002 engine & MS2B gearbox 2.3 ratio and 13 X 9 .55 Right Hand prop will do 5 knots at 2000 revs, but only 1 knot into a force 7 in a flat river mouth. The engine has had new piston rings and the valves ground in, and runs well with no black smoke but still puts out "blue haze". Just discovered from gearbox installation instructions that the control cable should move the selector forward for reverse, but mine is set up opposite way with a Right Hand prop. Will this affect power output, or cause gearbox wear, or can I carry on running in reverse for ever?
