GraemeS
When removing the push rod lift it just a bit and wiggle it around so the tappet falls away. This saves having to try and locate it if you totally remove it due to oil suction at the push rod end.
If I remember correctly there are two bolts that hold the rocker arms on. So if I take the rockers off I'll be able to take each push rod out and check them. If I roll them on a piece of glass and use gauges I should be able check for straightness. They are ground rods so I presume i'd expect them to be within 2 thou or am I being a bit hopeful?
Anyway thanks for the suggestion. If it is bad news can I get replacements do you know? Graeme
