Neil_Y
problems with the stop lever (apart from impossible to get to) Lever rotates but it's not turning the shaft that goes into the pump. Is that a common problem. It has a grub screw that's slipping on the shaft. I'm going to try to get to it via a cockpit locker but it looks very tight. Should shaft have a drilled dent to locate grub screw? Boat is an NF with 110 saildrive.
Thanks, I'm hoping someone has fixed this problem and has advice.
