smb
Does anyone know if there is one and where it should be on this engine? Since owning the boat I have never found one so assumed that there was not one fitted by design. However, a recently acquired workshop manual suggests there should be one and points vaguely to the area around the front end of the oil cooler, but using mirror, torch and 'blind' digital photography there is no anode obvious.
(I would point out that the oil cooler is beneath the heat exchanger which is beneath the inlet manifold, and the engine is in a narrow pit beneath the saloon floor, so investigation without dismantling from the top down is fairly difficult).
What a photo did reveal, on the front end of the oil cooler, is what looks like a threaded hole with a recessed plug in it. I am now starting to worry that that could be the sheared off remnants of an anode and I will have quite a job on to extract and replace it.
Any experience shared would be welcome.
steve
steve
